computer for diff vehicle question
Old Dec 19, 2005 | 08:54 PM
goshawk23's Avatar
Truck addict
Default computer for diff vehicle question
what is the difference in the tahoe computer and the truck computer? if i took a 01/02 pcm from a truck and flashed a tahoe vin in, could i tune it with hpt? or is the software only going to allow for truck vins.
what i am getting at is i (sisters) have a tahoe that needs a tune.
Old Dec 20, 2005 | 12:49 PM
BigKID's Avatar
No you cant. Tahoe/Suburban licenses are seperate from the trucks. Our cable will not connect to a Tahoe to read or flash the pcm. Physically I believe the pcms are the same but what you could do is get a pin diagram for the pcm harnesess for both vehicles and compare. If they are the same, the pcm's will be interchangable. You can also have some one check the service numbers for each pcm to see if they are the same.
Old Dec 20, 2005 | 09:29 PM
budhayes3's Avatar
PT's Slowest Truck
Not to mention that Tahoes are Drive by Wire and 01/02 trucks have cable driven throttle bodies (unless they are equipped with traction control)
Old Dec 21, 2005 | 07:31 PM
Nick™'s Avatar
yeah, but there is more than one table....
I imagine you could completly write over it with the truck tune, using a truck VIN, now if it goes to the dealer and the plug it in you will probably confuse the out of the technician b/c the VIN won't match the truck. Maybe double check to see if the part numbers are the same for the PCM in the trucks and Tahoes, the only differences I can think of would be the VIN, which you can alter with HP Tuners by writing over the existing tune as far as I know.
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bsn1989
Jul 16, 2015 08:20 AM
grantpo
Jul 15, 2015 12:21 PM
