Check this for me
Old Dec 9, 2007 | 04:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Check this for me
So I'm a real newbie when it comes to HPT and tuning. Understand the basic principles but no way I'm messing with my tune for a while.
I scanned a nitrous run (see hpl below), take a look!
In a previous scan I did get some KR, I sent my tuner (Rick@synergy) the log file and he made some adjustments in the tables taking some timing out of the high load area. It's pretty awesome I can send him scans and he can send me revised tunes, just like that!
Here's what I don't quite understand. I started this scan rolling about 42mph, when I nailed it I shifted into 2nd. (from 4th) and the tires broke loose until I let off the throttle leaving a ice long patch of double black lines. Why does the scan show that I was going 85? Aren't the speed sensors in the front? Could I have possibly been going 85mph spinning all the way up from 42?
Tell me what you see and how you see it, thanks!
Old Dec 9, 2007 | 05:09 PM
Mort's Avatar
When you spin your tires your speed is based on the RPM of the input shaft and maybe the output shaft of the transmission so the tires spin and the engine RPMs climb and the speed sensors think you are going faster than you are. Your tires were spinning at 85 mph.
Old Dec 9, 2007 | 05:38 PM
CHEVRACER83's Avatar
+1 your vehicle speed sensor (vss) told your computer you were going 85.... which in all truth your tires were!! your truck just didnt wanna follow suit your vehicle speed is taken at the output shaft so if your tires break loose that is the reading it shows
Old Dec 9, 2007 | 05:41 PM
trever1t's Avatar
ha ha, I'm a dork! I thought the front wheels had speed sensors Doh! Speaking of which, I have DTC's for FL/FR wheel speed sensors wtf?
Old Dec 9, 2007 | 05:44 PM
you have speed sensors most likely in the front, but those are used the ebcm to make abs braking calculation
Old Dec 9, 2007 | 05:47 PM
trever1t's Avatar
I have DTC's for both, I took it to my dealer and they told me not to worry about it?
Old Dec 9, 2007 | 05:49 PM
b.s. send me the codes.. i will run them right now... i can get into my work computer
Old Dec 9, 2007 | 05:51 PM
trever1t's Avatar
[PCM] P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency (Pending) (History) (Immature)
[Brake] C0040 - RF Wheel Speed Circuit Malfunction (SES) (Old) (Immature)
[Brake] C0035 - LF Wheel Speed Circuit Malfunction (SES) (Old) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Complete
EGR System: n/a
Thanks Shannon
Old Dec 9, 2007 | 06:01 PM
nightrunner's Avatar
Mr. Obvious
dont kid yourself (and us), pretty soon you will be like dewey and be logging your truck on the way to work and tweaking the tune while your on break
KySilverado's Avatar
Looking at the scan previous to the romp it appears that you are cruising at somewhere well above 14:7/1 AFR. Do you have a lean cruise setup going on?
