can grams/cylinder be converted to KPA in efi live
Old 01-30-2012, 11:13 PM
oldred95's Avatar
Default can grams/cylinder be converted to KPA in efi live
I cut my teeth on OBD1 using Tunerpro RT and EVERYTHING to do with vacuum was in KPA. I don't know what this grams/cylinder stuff is on the spark and Map psi on the VE table but is there a way to make EFI live display anything vacuum related in KPA?
Old 01-30-2012, 11:15 PM
Resident Retard
BlackGMC's Avatar
g/cyl = VE*MAP/charge temperature
just do the math to solve for MAP....
Old 01-30-2012, 11:42 PM
oldred95's Avatar
But can I somehow change the formula so it shows KPA on all vacuum based tables in EFI live? .044 grams/cylinder doesn't mean jack to me. KPA is so much easier to understand.
Old 01-31-2012, 03:27 PM
9 Second Club
Rhino79's Avatar
The spark tables use the g/cyl instead of kpa. Every ls platform I've seen does. The tables are what they are, I prefer the g/cyl because in any given log 98 kpa may be .44 or .88 g/cyl depending on how much air your setup will pump.
Old 01-31-2012, 03:37 PM
Mod with training wheels
smokeshow's Avatar
Grams/cyl = torque. It should mean something
Old 01-31-2012, 03:40 PM
I have a gauge for that
Atomic's Avatar
this thread reminds me of this
Verizon Math Fail - YouTube
shawn96gmc
05-17-2016 04:15 PM
cams 98 silverado
10-26-2015 05:12 PM
kr1s
08-24-2015 05:34 PM
GMCtrk
07-17-2015 06:39 PM
Quick Reply: can grams/cylinder be converted to KPA in efi live
