Can a 6.0 run on a 5.3 tune?
Old Jun 29, 2010 | 01:31 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Can a 6.0 run on a 5.3 tune?
I was planning on installing my 6.0 this weekend but Charlie Wheatley cant get a pcm to me untill later next week at the earliest. So I guess Im wondering if/how good will a 6.0 run on a 5.3 tune? Will it hurt anything? If it wont run on the tune or risk hurting anything Ill try and wait tell the following weekend, thanks guys
Old Jun 29, 2010 | 01:37 AM
Mangled03gmc's Avatar
Baltimore Whore
Drive it normal and it should run fine. But I mean NORMAL I ran around on a 4.8 tune with my 6.0 for a good bit, that was with a cam also.. So yes is the answer
Old Jun 29, 2010 | 04:17 AM
KleenHall's Avatar
for some people there are no problems...for some the truck doesnt start
i ran mine for 3 months and i beat on it hard, never had one issue
Old Jun 29, 2010 | 10:56 AM
Piss Pumps for Sale
hmm guess the ol 6.0 swap is a go this weekend, lol hopefully it will start!
Old Jun 29, 2010 | 01:42 PM
2001CamaroGuy's Avatar
Should work ok. The MAF, MAP, and O2s will still read the same and they are what control your closed loop/driving operation. The open loop could off quite a bit but that's mostly cranking, cold idle/driving, and WOT.
It might crank hard and I would guess going WOT would be something to avoid.
Even though the MAP will read correctly, the VE table is in %-of-displacement. The computer thinks you have a a 5.3 and so it will calculate the fueling based on that size. Obviously, 95%VE on a 6.0 (342CIs of air) is more than 95% on a 5.3 (310CIs of air), thus you will be lean with your 5.3 tune. It should be close enough to not really be a major issue (in this case only 32CIs of air) but it's just something to keep in mind.
Only big issue to point out is DO NOT go changing your injectors (didn't know if you had any plans to) without the tune as the fueling will be way off.
Old Jul 10, 2010 | 08:52 PM
Piss Pumps for Sale
so did the swap and my cammed 6.0 will not idle on my 5.3 tune, new pcm will be in this week so hopefully that will fix the idleing issue
Old Jul 10, 2010 | 11:52 PM
amadeospike's Avatar
make sure u tell your tuner if what injectors you will be using and i would do a wideband to calibrate the MAF to get the best performance
ferrellrooster
Mar 6, 2025 03:22 PM
stealthperf
34
Feb 14, 2016 11:35 AM
DrX
Aug 28, 2015 08:50 AM
steves86ta
Jul 28, 2015 10:21 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
