Blinking SES Light
Old Mar 5, 2012 | 05:14 PM
cammed00's Avatar
Angry Blinking SES Light
Sometimes if let's say I'm stopped at a red light or a RR crossing for to long and I barely let off the brake and coast forward my truck kinda "hops" and then my SES light will blink for about 10 seconds then go off and maybe come on again just depending on how long I'm stuck in one place and not moving. What could be the problem?
Old Mar 5, 2012 | 05:39 PM
pasadenaman's Avatar
for me it was a bad injector. 1st time i saw the blinking ses it tripped me out, thought i was going to have a dead engine soon. Go get it scanned to see if its missfiring and which one it is and go from there.
Old Mar 5, 2012 | 06:05 PM
cammed00's Avatar
Where can I get it scanned?
Old Mar 5, 2012 | 06:24 PM
terravast4's Avatar
go to autozone ...or any parts store should scan it for you for free
Old Mar 5, 2012 | 06:27 PM
cammed00's Avatar
They can pull it up even though it's not staying on it just blinks sometimes?When I plug in my programmer and run the scan tool on it nothing comes up.
Old Mar 8, 2012 | 01:21 PM
Pull your plugs and check each one on this link
You could try a sea foam treatment in the tank, then later try the sea foam spray can with the straw to try to clean things internally
Old Mar 8, 2012 | 01:32 PM
TXsilverado's Avatar
blinking SES light means random multiple misfire. pretty easy to diagnose. its guna be eiather a plug, wire, injector or coil pack. have fun figuring out which one it is. do you have access to a live scanner?
Old Mar 8, 2012 | 02:14 PM
cammed00's Avatar
I'm runnin seafoam in my tank now but do you think it could be that spark plug boot grease cuz I put some on acouple of my boots and that's when it started
Old Mar 8, 2012 | 02:15 PM
cammed00's Avatar
I don't have access to one and the dillhole at autozone can only do check engine lights so I went to a shop over here in Saginaw where I work and they wanted to charge me $60 to hook it up and tell me so I just turned around and walked out.
Old Mar 8, 2012 | 02:49 PM
i would try this then, and i get to keep it
You will figure it out... I remember it took me a few days to nail it. Ended up buying an injector from ebay to remedy the problem. For you it could be anything that Tx mentioned
