Battery light comes on and off
Old Apr 23, 2006 | 11:02 PM
Dark Halo's Avatar
Default Battery light comes on and off
My battery light keeps comming on and off while the truck is running, this happens after putting on a new belt any idea what might be wrong. Is the belt to long maybe? I have a 200amp alt and eletric fans, and a small amp for 1 sub and 2 6x9's.
Old Apr 23, 2006 | 11:13 PM
thunder550's Avatar
High on diesel fumes
If you alt is not factory it probably doesn't have the right regulator to communicate with the PCM. As long as your voltage is ok then you can have the battery light turned off in the tune.
Old Apr 24, 2006 | 01:26 AM
Question
The regulator could be bad. Does it come on and off if you hold the idle at 800 or 1000 rpm's? If the light goes off holding that idle, then the idle may need to be raised. If the idle is already set correctly, then you may need to get a different alt pulley to raise the alt rpm at idle. Is the problem just at idle? I should have asked that from the beginning. Why not just use a O.E. 145amp alt? With what accessories you are using, the 145 amp alt should be more than adequate. IMO
Jim
Old Apr 24, 2006 | 12:45 PM
chrisj6's Avatar
You can disable the L and F terminal codes in the pcm, thatll take care of that! I had to do it when I changed from a 99 to an 01 pcm.
Chris
Idryfly5
Sep 2, 2022 08:55 PM
RustyD
May 23, 2016 07:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
