Bad OBDII port??
Old Jan 29, 2011 | 06:49 PM
charcoal03silvy's Avatar
Default Bad OBDII port??
Bought a gauge off a member here that plugs into the OBDII . Works on every vehicle i have tried it on but mine. its got to be my truck. Any ideas?
Old Jan 29, 2011 | 07:10 PM
MikeGyver's Avatar
Did you check your fuse? It's the cig lighter fuse, isn't it people?
Old Jan 29, 2011 | 07:16 PM
Black'Rado's Avatar
cig lighter or accesory? one of the other
Old Jan 29, 2011 | 07:32 PM
which one is that?
Old Jan 29, 2011 | 08:09 PM
03sierraslt's Avatar
Drivers side of dash, pull the panel and look at the fuse diagram.
Old Jan 29, 2011 | 08:16 PM
Pulled the AUX power fuse and it looked like all the rest of em that are working just fine.
Old Jan 29, 2011 | 08:48 PM
scooter k's Avatar
It's the cig lighter fuse in the underhood fuse block that provides power to the ALDL connector
Old Jan 29, 2011 | 09:08 PM
It looked fine, I'll replace it anyhow with an extra I have to see if it works.
Old Jan 30, 2011 | 01:02 AM
andrew383's Avatar
traveling mod
How old is the gauge?? I know some of the earlier ones needed power and some didnt..
The 2 i have in my silvy dont need power run to them but i have an older one that needs 12v for it to turn on...
Did you check to see if it still works on the other trucks you hooked it up to before??
Also what did the seller have it installed in??
Have you posted on the aeroforce forum with this problem???
Old Jan 30, 2011 | 05:23 PM
Doesn't need power. I plugged it into my friend's 99 and my dad's 04 and it worked perfectly fine. Seller's truck was an 01. It is for sure NOT the gauge, its my OBDII port
