Anyone want to help me with a 2 bar? (possible bad map)
Ive been helping a buddy get his truck switched over to a 2bar. Its a 99 4.8 with a whipple on 8lbs. I've never messed with a 2 bar before.
I upgraded the os, copied the old ve to corresponding areas on the upgraded os, and set these codes to no error: 0101,0102,0103. The truck will not start. It smells ridiculiously rich.
I checked the scanner, that is not setup for a 2 bar yet, and the map sensor read 105kpa during cranking. It never budged. My buddy told me the sensor was for a 2005 or 2006 cobalt ss. It was purchased from o reilys. I'll put a link below to show which one I THINK IT IS.
MasterProŽ Ignition 2MS15 - MAP Sensor | O'Reilly Auto Parts
Does this sound like a symptom of the wrong map sensor?
Yes I did a write entire. Each revision after, I just did a write calibration. I'm using hptuners to tune with. Map Sensor Linear: 200kpa , Map Sensor Offset: 10.33kpa
Output voltage reads 4.8v with key on, engine off. I'm guessing I dont have my config setup appropriately to see the full range of the map. So, this could possibly be reading 210kpa. Ive heard of some of the wrong map sensors reading backwards.
Aha! That is a 1bar map. The pcm figures out what the pressure is based on the voltage...the sensors sole purpose is to output the voltage relative to the pressure it sees. A 1bar map will read ~5v at 1atm, a 2bar will read 5v at 2atm, 3bar 5v at 3atm, etc. Also works for half way in the range... 1bar will read 5v at 1atm, 2bar read 2.5v at 1atm (half its range), 3bar will read 1.67v at 1atm (1/3 its range).
You want the GM P/N: 12580698 or AC Delco: 213-1631
EDIT: Just checked the logs and the MAP KPA stayed at 105kpa, but the MAP Voltage went down to 2.8V.
Thanks bud. I didn't realize this. I will set them up appropriately on the next revision.
calsdad
Jun 14, 2023 11:07 PM
