Anyone want to help me with a 2 bar? (possible bad map)
Old May 10, 2013 | 11:13 PM
kelsey_canard's Avatar
Default Anyone want to help me with a 2 bar? (possible bad map)
Ive been helping a buddy get his truck switched over to a 2bar. Its a 99 4.8 with a whipple on 8lbs. I've never messed with a 2 bar before.
I upgraded the os, copied the old ve to corresponding areas on the upgraded os, and set these codes to no error: 0101,0102,0103. The truck will not start. It smells ridiculiously rich.
I checked the scanner, that is not setup for a 2 bar yet, and the map sensor read 105kpa during cranking. It never budged. My buddy told me the sensor was for a 2005 or 2006 cobalt ss. It was purchased from o reilys. I'll put a link below to show which one I THINK IT IS.
MasterProŽ Ignition 2MS15 - MAP Sensor | O'Reilly Auto Parts
Does this sound like a symptom of the wrong map sensor?
Old May 10, 2013 | 11:37 PM
Atomic's Avatar
I have a gauge for that
When you upgraded the os did you do a write entire? What are you using to tune? Set the offset and slope correctly?
Old May 10, 2013 | 11:40 PM
Yes I did a write entire. Each revision after, I just did a write calibration. I'm using hptuners to tune with. Map Sensor Linear: 200kpa , Map Sensor Offset: 10.33kpa
Old May 10, 2013 | 11:44 PM
Atomic's Avatar
I dunno about the sensor...what is the output voltage with key on engine off? Should be about 2.45v.
Old May 10, 2013 | 11:47 PM
Output voltage reads 4.8v with key on, engine off. I'm guessing I dont have my config setup appropriately to see the full range of the map. So, this could possibly be reading 210kpa. Ive heard of some of the wrong map sensors reading backwards.
Old May 10, 2013 | 11:52 PM
Atomic's Avatar
Aha! That is a 1bar map. The pcm figures out what the pressure is based on the voltage...the sensors sole purpose is to output the voltage relative to the pressure it sees. A 1bar map will read ~5v at 1atm, a 2bar will read 5v at 2atm, 3bar 5v at 3atm, etc. Also works for half way in the range... 1bar will read 5v at 1atm, 2bar read 2.5v at 1atm (half its range), 3bar will read 1.67v at 1atm (1/3 its range).
You want the GM P/N: 12580698 or AC Delco: 213-1631
Old May 11, 2013 | 12:01 AM
Beatdown Z's Avatar
Laid Back
set the MAF codes to NO MIL LIGHT. Having them set to no error will not fail the MAF.
Old May 11, 2013 | 12:07 AM
THANK YOU SO MUCH! This makes perfect sense. I do have a question about this though. I understand the 1 bar map reading 5v/105kpa with the key on and engine off, but why did it not fluctuate at all during cranking? Surely cranking should have created some sort of vacuum. Is it because the upgraded operating system?
EDIT: Just checked the logs and the MAP KPA stayed at 105kpa, but the MAP Voltage went down to 2.8V.
Thanks bud. I didn't realize this. I will set them up appropriately on the next revision.
Old May 11, 2013 | 08:58 AM
Atomic's Avatar
When you log map make sure you log the special 2 bar one, and not the normal one. It should be the next one on the list.
Old May 11, 2013 | 11:28 PM
UnVmy5.3's Avatar
Yes only a dealer can get a 2 bar.
calsdad
Jun 14, 2023 11:07 PM
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
