Anybody's check engine light come on after playing with idle cable?
probably bad TPS voltages. when you pull the cable tight to up the idle, it will also change the voltage that the TPS reads. change your idle rpm with hp or efi live. you will need to hook up some scanning software and close the throttle body back to the proper idle voltage that the computer looks for.
Depending on what you did you could do a tps relearn.
unplug the tps and turn the key to run. Wait a few seconds and turn it off. now plug in the tps and do the same thing. once you crank it it should be recalibrated to that point being zero. handy trick!
tweeder
Sep 18, 2015 11:02 PM
bsgiffor
Jul 19, 2015 11:14 AM
Suburban2500
Jul 14, 2015 02:10 AM
