Alternator losing voltage with high boost
Old Jul 27, 2018 | 12:45 AM
AkSSS's Avatar
Default Alternator losing voltage with high boost
I keep getting voltage drops from my alternator when I have my truck making a little steam. Every time it seems to be right around 5800rpm it drops to about 12.0V. In turn it is dropping the voltage to my Meth system and it goes lean for about 1sec until the shift. I tried a new alternator because I was thinking the brushes were worn. And it did seem to clear up. The new 145amp alternator now has about 1200 miles on it and just had the same issue at the track last weekend. Had the truck turned up to about 18psi. Doesn't seem to drop voltage under 15psi. I don't see alot of belt dust around the alternator like it could be slipping. Doesn't mean that is not it.
Before I go buy another alternator and a gatorback belt. Any thoughts? Ideas? Both Alternators were acdelco units.
Old Jul 27, 2018 | 11:41 AM
Vortec350ss's Avatar
When does your second pump kick on? Could it be something to do with that?
I would imagine going lean is more than just the meth. It would effect your primary fuel system as well. Fuel pumps flow less and injectors act different as voltage drops.
Old Jul 27, 2018 | 11:45 AM
AkSSS's Avatar
I'm sure your correct. It would effect way more than just the meth. My second pump kicks on at 7psi. So I'm pretty far into the dual pumps running. Weird thing is this went away for a little while with the new alt. Maybe the new one is wearing out already?
You spin your motor way above 6k don't you? Have you ever had Alt issues with higher rpm?
Old Jul 27, 2018 | 12:10 PM
03sierraslt's Avatar
I never had issues, I hit 7
Old Jul 27, 2018 | 12:12 PM
I did, and I do now as well, but I haven't had this combo running for long. I have not had issues with voltage.
Old Jul 27, 2018 | 07:30 PM
AkSSS's Avatar
Ok. I'll go buy another new Alternator.
What is the best belt out there to get anymore? I always just buy a gates belt. Goodyear Gatorback worth the money?
Old Jul 27, 2018 | 09:18 PM
BudRacing's Avatar
Have you upgraded any of the wiring? I'd do a big 3 upgrade before replacing the alt again.
Old Jul 28, 2018 | 12:22 AM
AkSSS's Avatar
i actually haven’t done this upgrade yet. I kinda forgot about it. I will get on this upgrade this week and see if that changes things. Good thinking! Thank you for the input!
Ill look it up. But isn’t it 4 wires? 3 grounds(battery, alt. bracket and chassis grounds) and the alternator to battery power wire?
Old Jul 28, 2018 | 01:40 PM
MikeGyver's Avatar
New or rebuilt alternator? I recommend new.
Old Jul 28, 2018 | 02:04 PM
AkSSS's Avatar
First one was a reman. The second one was a new ac Delco.
