All of this because of a converter???
Well I installed my 3rd Fuddle converter last week and still getting ses codes. I barrowed a buddies scan tool and this is what showed up from the freeze data:
DTC that caused the freeze data=PO300
Throttle position=0.0%
Load value=3.9%
RPM=885
Air flow rate=10.21 GR/SEC
Map sensor=35 KPA
Coolant temp=82º
STFT#1=0.0%
LTFT#1=2.3%
STFT#2=0.0%
LTFT#2=1.5%
STFT#3=50.0%
LTFT#3=-18.8%
STFT#4=57.0%
LTFT#4=-3.4%
Vehicle speed=1 MPH
Fuel system=#1 & #2 open
All of this happened after I installed the Fuddle converter. I'm not saying that it is the converter, but if it's the tune, this ses thing just happened by coincidence after installation???
I started the truck and drove it for awhile and to check fluid levels and ses codes ever since.
What is ya'lls analogy???
James
Load value=3.9%
RPM=885
Map sensor=35 KPA
Coolant temp=82º
STFT#1=0.0%
LTFT#1=2.3%
STFT#2=0.0%
LTFT#2=1.5%
STFT#3=50.0%
LTFT#3=-18.8%
STFT#4=57.0%
LTFT#4=-3.4%
Vehicle speed=1 MPH
James
Originally Posted by Flyer
That is very common with with cammed motors. It's a random misfire code. The converter didn't cause that. Your problem is elsewhere.
Thanks for the input.
James
Originally Posted by joshluther
Thank you very much!!!
James
How do I change this text
Originally Posted by closet red neck
Very useful thread!!! I was thinking the same thing about the less weight in rortating mass. The engine isn't working as hard anymore with the lighter verter. Allen is going to look into it for me this next week.
James
James
I beleive I used the 5.3 tables for the 6.0, I can't remeber now.....
Originally Posted by Wilde Racing
I had the same issue when I installed the small ART CARR I had, The truck Torque converters are very heavy. Replace them with something a lot lighter, the computer would like to know about it. lol
James
How big is your torque converter???
The one i just put in is a 10", i have no problems with misfires..
it freakin revs up faster now!
James
jscherbs
Mar 24, 2017 07:20 PM
jtphelps289
Sep 11, 2015 06:37 PM
