AFR position
Old Aug 7, 2008 | 10:19 PM
nonnieselman's Avatar
Do you not have Rear O2s?
Thats what i did awhile back was gut my cats and remove the Driver Rear O2 and put the LC-1 there..
Old Aug 7, 2008 | 10:29 PM
charcold-bowtie's Avatar
Key words
Old Aug 8, 2008 | 03:35 AM
viciousknid's Avatar
Where's the Beef?
So when I'm lookin in the manual, I should look for a 0-1 volt Narrow band option correct?
Assuming it has that option, do you have to splice into it so that the Gauge and PCM are both getting a reading?
See sig. No rear 02's with an ORY
I don't mind welding in a new bung but if I can save myself the trouble, i'd rather just take out one of the 02's.
Old Aug 8, 2008 | 07:09 AM
KySilverado's Avatar
Yes, look for an output from the AEM controller for narrowband simulation. Just one wire. What I did is removed/cut the connector from the OEM NB sensor. Wired the NB output from the PLX/LC1 to that pigtail and plugged it back in so that I could just throw a NB sensor back in if need be.
If you have a narrow band AFR gauge then yes you could use this NB signal to drive it. Chances are the AEM came with a WB gauge, in that case no this gauge will not need this NB signal wire.
Old Aug 8, 2008 | 10:46 AM
Where's the Beef?
http://tunertools.com/prodimages/AEM...structions.pdf
that link is to the manual. If you'll see page 9, does that mean that If I put it on the p4 setting, that I can in fact run it as my front o2 sensor?
Old Aug 9, 2008 | 07:08 PM
03chevy5.3rcsb's Avatar
Just my .02, but I could drill you a hole and weld a bung in about 15 min., I'd rather do that then the other.
Old Aug 9, 2008 | 07:17 PM
dewmanshu's Avatar
Moderately Differentiated
Man I'd LOVE to monitor both banks. Just for my own madness.
Old Aug 9, 2008 | 07:29 PM
I read through the manual. It appears the setting the to P4 does output a narrow band signal but nowhere does it mention that it emulates a NB sensor so I don't know. Another thing is that if you set it to P4 apparently the white wire becomes the 0-1v output wire. Then you wouldn't be able to data log AFR.
Old Aug 9, 2008 | 07:42 PM
dewmanshu's Avatar
Well, your calcs are designed for 0 to 5 volts anyway. Wouldn't do ya any good besides reading the voltage like you already do.
Old Aug 13, 2008 | 01:15 AM
Where's the Beef?
I'm just going to weld in a bung then. Out of curiosity is there any legitimate reason to run a wideband on both banks.
Porscharu914
14
Jan 20, 2016 10:45 AM
97_ek
Sep 23, 2015 09:16 PM
lxcoupe
Sep 22, 2015 02:50 PM
xtrooper89
Sep 21, 2015 06:03 AM
xerox17
Sep 5, 2015 01:23 PM
