AFR clarrification!
GFYS and STFU
Sooo...Need some clarification on something.
I read that it's been found that somewhere between 13.2:1 and 13.4:1 is an ideal AFR for best power. However I'm under the impression that between 11.5:1 and 12.5:1 is the sweet spot of us!
Are there different ideal AFR's between N/A and F/I set-ups?
i am dissapointed.generally, n/a like to be around 12.6-12.8 for best power. nitrous should be a little richer, low 12's is what i run.
for FI, you run much richer than n/a, some run low 11's AFR, depends on amount of boost/timing/octane of gas and if meth will be used.
i think most FI guys are around mid-high 11's AFR at WOT.
your cruise, however, should be around 14.7-ish (stoich) although i wonder if i can go leaner than that at cruise and pick up any gas mileage.
GFYS and STFU
are you serious? all that **** done to your truck and you just read that FI has different AFR...
i am dissapointed.
For best economy you swing to the other side of stoichiometric balance with a target of λ = 1.05 (about 15.5:1 AFR)
lambda is another confusing coversion, dont worry about it lol. I mean the conversion is easy, but im not used to it and I prefer AFR.
Looking at my tune, I command around 11.5 AFR WOT from 3500 and up RPM.
My lean cruise is commanding 15.3 AFR. Some of the efilive forum guys are commanding 16+ during lean cruise. watch timing in this discussion as well.
GFYS and STFU
Widebands are rated to operate between 0.8 bar and 1.3 bar to be reasonably accurate. Because mine routinely see's up to 4 bar with it's location the sensor reads furthur from stoich. So when I'm rich it reads richer than what it is and when I'm running lean it reads leaner than it actually is. At WOT I'm seeing between 9.6:1 and 10.2:1. I think right now I'm in the high 10's/low 11's...but not sure.
