AEM wide band
Old Feb 19, 2014 | 10:21 AM
BigDaddy0381's Avatar
Default AEM wide band
I just hooked this up, can anyone tell me why it jumps around or is it normal? or could it be my tune is that off? this is my first one so be easy.
Wide band - YouTube
Old Feb 19, 2014 | 10:42 AM
where its located in pipe
Old Feb 19, 2014 | 11:23 AM
Ferocity02's Avatar
That's not normal. Check for an exhaust leak.
Old Feb 19, 2014 | 11:25 AM
TXsilverado's Avatar
should have got a MTX-L J/K it's kinda an inside joke that i'm sure a few others will catch onto
Old Feb 19, 2014 | 11:32 AM
I seen your thread,,LOL
So could it be tune? I'm going to check for leaks now. Dose it need to heat up to work correctly? think its to far back from flange?
Old Feb 19, 2014 | 11:56 AM
Ferocity02's Avatar
Probably not in the tune, that's a lot of fluctuation. Usually the trims will hold it fairly steady. Mine bounces fairly consistently from 0.99-1.03 lambda. Was it fully warmed up/in closed loop?
The sensor does need to warm up, but it has an internal heater and takes maybe 10 seconds to start reading fairly well.
Old Feb 19, 2014 | 12:03 PM
Did I need to hook it up not screwed into the pipe and let it learn or anything? I just went straight in and here we are.
Old Feb 19, 2014 | 12:31 PM
03sierraslt's Avatar
That's not the tune, that's a exhaust leak or sensor issue.
Old Feb 19, 2014 | 01:49 PM
I put the scope on it and no leaks, i to the sensor out and cleaned the part that reads and now it looks like this. it had a little anti siez on it.
slow roll light throttle and idle
Wide band 2 - YouTube
1/4 throttle
Wide band 3 - YouTube
Old Feb 19, 2014 | 02:12 PM
looking a lil rich there.
