Adjustable fuel pressure regulator
Old Jan 25, 2009 | 09:26 PM
hobbesnmina2001's Avatar
Default Adjustable fuel pressure regulator
Can you guys tell me if anyone has an adjustable fuel pressure regulator that will bolt on in place of the factory regulator on 2003 Silverado 6.0 L?
Thanks
Carlos
Old Jul 8, 2009 | 04:34 PM
Most Hated's Avatar
x2...................
Old Jul 19, 2009 | 11:57 AM
X3...........
Old Jul 19, 2009 | 12:01 PM
Mangled03gmc's Avatar
Baltimore Whore
Why do you want to go to a adj reg??? The factory one works great,(even for FI) unless you are changing to a diff style intake
Old Jul 19, 2009 | 12:22 PM
Dark Halo's Avatar
I think someone had said you can get one at oreillys. I am not sure how adjustable they are but you might check there first.
Old Jul 19, 2009 | 04:01 PM
1Bear's Avatar
I don't know how far they will go, but it is a decent amount. A friend of mine has a '99 that is equiped with the factory adjustable regulator. He checked his pressure and it was set at 48psi, he adusted it back to 62psi without a problem. Of course he needs to get put back on the wideband, as it was tuned at the 48psi and now is rich as all get out.
Old Jul 19, 2009 | 06:35 PM
KLUG'S SS's Avatar
FormerVendor
The IFR (injector flow rate) table will need to be rescaled correctly if the fuel pressure is raised at the fuel rail. If you can get more pressure out of the regulator it is somewhat of an alternative to buying larger injectors as the higher pressure will make the injectors you currently have act larger.
I too would be curious if I could get an adjustable reg.
Old Aug 2, 2009 | 09:42 AM
blown3qtr's Avatar
There is an adjustable ACDelco available. Not sure of the part number. I bought one. Does your stocker have a lil torx screw in the middle? That's all the adjustable one has. you can adjust the spring pressure.
Search you may find the part number. I think Ray (Supersub) gave me the part #.
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
