99 tahoe cranks but won't start
Old Aug 25, 2006 | 08:20 AM
primal1's Avatar
Default 99 tahoe cranks but won't start
i don't get a security light, so i don't think its passlock. i don't hear the fuel pumpwhen i turnit on ot put 12 volts to the bypass wire under the hood. the pump was replaced about 8000 miles ago. could this be the connector/corrosion problem i've been reading about.
Old Aug 25, 2006 | 09:41 AM
slowec's Avatar
You need to check that connector at the sending unit. Use a jump box or jumper wire to give it 12 volt @ the connector by the tank. Still no noise??? pull the tank. At that point ithas to be the pump or sending unit.
Old Aug 25, 2006 | 01:10 PM
primal1's Avatar
it is intermittant. thats why i'm thinking plug.
Old Aug 28, 2006 | 04:43 PM
primal1's Avatar
i'm getting 9.73 volts to the gray wire. when i wiggle the wire the pump turns on and off. i have a short somewhere.
SLOPONY
20
Oct 18, 2016 06:05 AM
WarbirdLS1
Aug 8, 2015 10:53 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GreyChevy
Jul 7, 2015 08:57 PM
