6 speed nnbs trucks gear indicator question
Old Nov 13, 2014 | 06:24 PM
Three6GMC's Avatar
Default 6 speed nnbs trucks gear indicator question
Anyone know what tells the gear indicator what gear the 6 speed trucks are in when in manual mode? I want to pull that little screen out of a 6 speed cluster and use it on a project.
Old Nov 14, 2014 | 01:07 AM
The TCM talks on the CAN high speed data bus to the ECM. The ECM then relays the PRNDL information over the databus to the instrument cluster When you put it in manual mode it display's M then when you start tap shifting and the numbers change all of that information is broadcast on the high speed data bus. The instrument cluster then gathers and hears this information off of the bus and displays accordingly.
Old Nov 14, 2014 | 01:12 AM
Three6GMC's Avatar
Cool thanks for the info
Old Nov 16, 2014 | 01:22 AM
Three6GMC's Avatar
Just curious you think you can post of a wire diagram of the harness that goes into our factory gauge cluster?
ferrellrooster
Mar 6, 2025 03:22 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
1320Chicken
Jul 14, 2015 10:58 PM
blackdc3
Jul 7, 2015 07:52 PM
