6.0 swap wiring/ computer
Old Mar 10, 2012 | 01:36 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
Lets just look at the 2005 Operating Systems (OS's). This way we will have only the CTS-V as a car abd all the opthers will be trucks
12591725 old OS -- New OS = 12592618
12592618 -- CTS-V, 4.8L to 6.0L Truck, Flex Fuel & Non Flex, All Trans options & H2
12606961
12612115 -- 8.1L
Template #04_06
12591725 or 12592618
12593555
Template #04_07
12606961
12592618 old OS & New OS = 12612115
Template #13_03 2005 CTS-V
12592618
My point is that OSID #12592618 could run every configuration or option that was used in all of the GM cars and trucks that ran the PCM #12589462, but everything will work in PCM #12589463 except DBC. 12589463 is missing the IAC Driver inside the PCM
Old Mar 10, 2012 | 03:51 PM
mitchellmade's Avatar
MASS seller approved
was offering my 03 harness only so you could have dbc and 4l80e wiring figured it would be easier for you but know that I look at it , it would make my project alot easier
Old Mar 10, 2012 | 10:27 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Damn!!! Thats some serious knowledge right there... CalEditor FTW!!!
Old Mar 11, 2012 | 08:44 AM
jmj85's Avatar
Cal, if I'm understanding you if I'm going to go DBC then use the 2001 computer if I go DBW use the 2005 computer. Thanks that helps. I think since a reprogram is needed either way and I'm leaning to keeping the auto track transfer case, I'm going to DBC with the 2001 comp cheaper and easier. Or so it seems
Old Mar 11, 2012 | 01:15 PM
FormerVendor
I updated this just a little. If it is green it will work
Old Mar 25, 2012 | 11:19 AM
sleeperlqx's Avatar
Originally Posted by mitchellmade
i have a harness out of a 03 2500 van for 6.0 and 4l80e thats dbc if your interested let me know
Will this wire harness work with a 01 PCM as I have DBC and I just did a 80e swap?
Will the 03 harness not be compatible with my 01 PCM? or Will it>?
I plan to send my PCM off to get re-segmented for 80e as well.
Need some input. I maybe interested in that harness.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
davis28905
Jul 8, 2015 03:20 AM
