5.3 surging when driving or in park/neutral and reving
Old Mar 16, 2011 | 11:48 PM
TXjeepTJ's Avatar
Default 5.3 surging when driving or in park/neutral and reving
I'm trying to diagnose a problem w/ a 5.3 truck engine that is in in a Jeep wrangler. It is running a flashed F-body PCM running the 5.3 program.
When you rev it to about 2k + it revs somewhat smooth but you can hear a change in tone every half a second
when you go to drive it, it bucks/surges and sometimes wants to die (mainly when you arn't on the gas and then give it gas)
I've check for vacuum leaks, I'm not perfect, but I'm sure I have cleared up any vacuum leaks. I checked the fuel pressure and it is getting over 50psi. I also switched out the throttle position sensor w/ one off another engine and it still does the problem. I also switched the MAF on it- still does the problem
what do you guys think I should do? could it maybe be one or two bad coils? anyone know how to checked the coils?
let me know anything you guys think I should try and I will, I need to get this thing fixed!
Old Mar 18, 2011 | 11:34 AM
01Blackerado's Avatar
Scan and tun software? Could be a anything honestly...vacuum leak, fuel trims out of wack, air leak, spark tables out of wack, IFR out of wack, A LOT of possibilties...scan it and post it and your tune
Old Mar 23, 2011 | 12:34 PM
TXjeepTJ's Avatar
I wish I had tuning software, the only scanner I have is OBD. Everything is normal with everything, except the oxygen sensors ST FTRM1 and 2 are jumping all over the place (going from -35% to +35%) I think the problem rests in the fact that it is a F-body PCM that the 5.3L program was put in. I think something got messed up with the tune
Old Apr 13, 2011 | 04:43 PM
67C10BUB's Avatar
I was wondering if you found the issue. I am having a similar issue with a 5.3L I put in my 67 C10.
Old May 11, 2011 | 03:52 PM
garomans's Avatar
Do you have the temp sensor plugged in? If not, the motor thinks its still cold and its chocking itself.
Choda
Jan 22, 2026 02:03 PM
05GMC4.8
Aug 7, 2015 09:55 PM
walledition
Jul 29, 2015 08:54 PM
elpyro89
Jul 28, 2015 05:51 PM
fillpot
Jul 26, 2015 07:21 PM
