4l80e questions
Old Aug 3, 2009 | 04:51 PM
thunder550's Avatar
High on diesel fumes
You sure your converter is locked in 4th at that point where you're comparing TIS and TOS RPM?
Old Aug 3, 2009 | 04:57 PM
nonnieselman's Avatar
Originally Posted by 53RUSSELL
NO, but shifts realy hard at part throttle and I want go back turn down the line preassure so just checking that way to see what I came up with. This only way no how check beside feel.
Ohh, are they stock values?
Its showing that its locked and the rpms are staying consistant..
Old Aug 3, 2009 | 05:58 PM
53RUSSELL's Avatar
I can feel the convert lock-up but the rpm doesn't really drop at 60mph.
When the convert locks-up at 45mph it drop alot.
Old Aug 3, 2009 | 06:57 PM
53RUSSELL's Avatar
Yes, did you look log file?
Old Aug 4, 2009 | 12:26 AM
53RUSSELL's Avatar
o.k yes the 80e has a input and output sensor.
I talked to the tranny guy and he said when the trans go's into forth gear the input out put shaft are spining the same speed. So you would take output and divided by the rpm give you the gear ratio.
Old Aug 4, 2009 | 07:18 AM
Mort's Avatar
I don't get it? The OD ratio is 0.75 so how can the input and output shafts be spinning the same speed? Please explain.
Old Aug 4, 2009 | 07:22 AM
KySilverado's Avatar
Third gear is 1:1. Not 4th which is .75:1
Old Aug 4, 2009 | 08:07 AM
53RUSSELL's Avatar
Sorry I’ll try to explain best I can.
It has to do where the sensor is located in the case and what parts they are reading. The input sensor is reading of the hub in the case witch is spinning in the third and forth gear the same speed as your output. So you will see the same speed as input and output in third and forth. So you will have divided you input or output by rpm to get your gear ratio. Sorry if doesn't help I’m not trans
GXPJAY
Feb 13, 2022 08:15 AM
Rafe19
Oct 18, 2016 12:27 AM
wcrum17841
Aug 24, 2015 08:30 AM
USMCvet0311
Aug 1, 2015 07:45 AM
