4l80e file segment?
Old May 20, 2014 | 01:07 AM
03 BLKTAHOE's Avatar
Default 4l80e file segment?
I'm in the process of finishing up my 4l80e swap but I need a to figure out what to do on the HD file segment?
As of right now the 80e trans is in and I purchased the Speartech wire harness with the vss connection. I've done some research and from what I gather I need my tune plus an Hd file that's closet to my tune which I then send off to Hptuners to have them do the segment for me?
The thing is on the Hd file I'm not sure what I'm looking for I've look thru multiple threads and it doesn't really say what to look for just the closet to my tune?
Also which my stock to or my adjusted tune?
How do I attach my tune it keeps saying its invalid?
Old May 20, 2014 | 02:26 AM
timmay208's Avatar
from HPT open your file goto edit and calibration details
whats your OS ID, then you can find a matching 4l80e with the same OS, send to HPT and they will converter it for you
Old May 20, 2014 | 02:46 AM
Thanks for the response and that seems pretty straight forward but do I send my stock tune or my modified tune or doesn't even matter? Once again thanks!
I would imagine that I should use my modified tune so that when I get it back there's no need to mess with the tune?
Old May 20, 2014 | 11:30 AM
timmay208's Avatar
what ever tune you plan on using on your truck, so you can just do a read of whats on there and use that
Old May 20, 2014 | 12:51 PM
Chevy_King1500's Avatar
hijacking....
my VCM OS ID: 1251002
when I click on the box that has the "HP OS" drops down the VCM Enhancements
1 bar map
2bar map
ETC..
Im running the 2 Bar OS and it says beneath that "Converted from 12212156"
Old May 20, 2014 | 01:47 PM
timmay208's Avatar
that im not 100% sure i would think you need to find one for 12212156 though
Old May 20, 2014 | 02:57 PM
foff667's Avatar
LS1TECH Sponsor
correct.
Old May 20, 2014 | 04:16 PM
Originally Posted by foff667
correct.
thanks
Old May 21, 2014 | 01:33 PM
correct.
got my new tune (80e) back this morning, Thanks for the fast turn around
Old May 21, 2014 | 01:34 PM
timmay208's Avatar
top notch service!
