4l80 swap need segment swap
Old May 31, 2016 | 11:04 PM
chevyboi925's Avatar
Default 4l80 swap need segment swap
so I did a 4l80 swap in my 06 1500 2wd Silverado used the nelson harness and I cant find or figure out how to tune/ segment swp please help I believe os is 12606807 some1 help me double check its the only number I see when clicking os in hp tuners 2.24 thanks
Old May 31, 2016 | 11:22 PM
FFDP's Avatar
2.24 is no longer support from HP Tuners.
Upgrade to 3.0 and find a OS that matches yours from a 2wd vehicle with a 4L80e. So like a 2500 chevy truck or similar. Then use the segment swapper built into the new 3.0. They have a thread on HPT how to use it.
Old Jun 1, 2016 | 12:09 AM
Does the operating system change if I had 3.0 because I've searched everywhere and can't find anything that matches operating system so what would be different if I had 3.0
Old Jun 1, 2016 | 08:25 AM
slvrram's Avatar
How to perform a segment swap using the segment swapper utility
Is the correct "how to" I believe. A lot of it is blocked because I'm at work, but I believe it is the one I followed.
Like the guy above stated, you need a file with the same OS. You can find the OS info in the drop down menu in HPTuners. Then proceed to the HPTuners tune repository and find a tune with the same OS and the 4l80e data.
Good luck!
Old Jun 1, 2016 | 08:43 AM
ok so found a 4l80 tune with same os but cant figure out how to segment swap I have my tune open then the matching 4l80 in compare then I'm stuck I go to calibration details but idk almost there or tune is still wrong and dosent enable segment swap?
Old Jun 1, 2016 | 09:30 AM
slvrram's Avatar
Do you have 2.25 or 3.0?
Old Jun 1, 2016 | 09:38 AM
I was using to .24 even though I like 3.0 better but all my tuners used 2.2 4 so that's what I used to be able to email Tunes back and forth and data log but I open 3.0 and figured it out it all seems to be ok quick question though so I did the segment Swap and everything saved and looks good the operating systems were the same but if for some reason they were at all different would it not be able to segment swap or would it but it would screw up the truck thank you and thanks for the help
Old Jun 1, 2016 | 10:26 AM
slvrram's Avatar
Excellent. You're very welcome.
Old Jun 1, 2016 | 10:47 AM
But real quick if this tune I chose wasn't compatible then the segments swap wouldn't of stuff for work right? I mean the operating system numbers where the exact same and everything seems to be working but just want to make sure before I put it in my truck
Thoagland
70
Sep 1, 2016 04:25 PM
Flewbyu123
Apr 9, 2016 12:39 PM
Jasinto78
Mar 30, 2016 07:20 PM
murderedSS
Mar 29, 2016 09:13 AM
Flewbyu123
Mar 16, 2016 09:29 PM
