4l60E is it time to go?
Old Aug 6, 2011 | 04:52 AM
kr1s's Avatar
Default 4l60E is it time to go?
Ok so i just did my 4.3 to 5.3 swap and i can already feel a difference, the only thing is that my trans is being really weird :/
It was fine on the 4.3 then when i swapped the 5.3 in it started acting up, when i put it in D it takes off in 3rd gear, so i have to manually shift to 2nd. I also have no O/D. I hooked up my scanner and i got these codes
P0463 Fuel sensor
P0713 Transmission Fluid Temperature Sensor Circuit High Input (which means?)
P0748 - Pressure Control Solenoid Electrical (what the hell is that?)
p0758 Solenoid Circuit B
p0785 shift timing solenoid malfunction
p1810 TFP Val Position SW Circuit Malfunction
Can this be fixed? Can this be caused by ground wires? Not enough fluids?
Anything? Also can someone tell me how many sensors go on the transmission? Its only 4 right?
Old Aug 6, 2011 | 07:26 PM
kr1s's Avatar
Vroom
Old Aug 7, 2011 | 10:18 PM
cfaluck13's Avatar
Did you happen to pinch a few wires somewhere like between the behousing? Or leave a ground off somewhere like on the back of the cylinder head? I can
check those codes for you later
Old Aug 7, 2011 | 10:40 PM
Suburbazine's Avatar
P0463 Fuel sensor
P0713 means that the PCM thinks the transmission is overheating (rather, it means that it is short circuited and shouldn't be)
The other 700 codes mean that you have a wiring issue. Did you have to modify any harnesses, or did you swap PCMs, or did you pinch the harness at the back of the engine?
Old Aug 8, 2011 | 01:39 PM
budhayes3's Avatar
PT's Slowest Truck
The P0748 is referring to the line pressure control solenoid, you may have an issue with the solenoid, or more than likely it's wiring, and the code may set under low voltage conditions caused by high electrical system demands, as stated here:
http://www.c-hock.com/downloads/gmfs/P0748.pdf
The info in that link is for an 02 Sierra, but I believe should be the same for you
Old Aug 11, 2011 | 03:51 AM
kr1s's Avatar
No i checked that :/
No i checked the harness and its fine, and its a original harness with original pcm
Hmmm i need to check the solenoids, see because it works sometimes! I hate that it will work for like 4min then go into limp mode, even if i clear the codes its still in limp mode . Then my girlfriends dad added like two extra quarts of tranny fluid -_- lol so i need to drain it out, even though i doubt that could be it.
I need to check ign0 fuse, i have read that that could be it also, or my ignition switch, if i'm not getting power, or my converter :/ ahhh there's sooo many things and i just wanna drive my truck with out having to manually shift from second to third. It suck! then i have a exhaust leak so people wanna race lol but there's no point cause i don't go anywhere!
I might replace the filter and oil, idk
XL7
May 5, 2022 01:48 PM
Ferocity02
Aug 7, 2015 08:50 PM
Sales4@Texas-Speed
Aug 3, 2015 03:57 PM
SleeperGMC
Jul 29, 2015 10:22 AM
cbhedrick
Jul 20, 2015 10:12 PM
