4.8, P-1SC, and a broken #7 piston
Just wondering if anyone has had any problems with running a ProCharger P-1-SC on the 4.8 @ 9 psi. I just replaced #7 piston (broken skirt). The guys at the shop told me that there must have been some kind of underlying problem and the SC just accelerated the failure. Any suggestions without a teardown to rebuild bottom end? I am also running Corsa exhaust, TR6 plugs, Taylor 10.4 wires, Flex-a-lite fans, powerstat, diablo. Thanks for any help you can provide.
I blew #7 on the 5.3. That appears to be the first cylinder to go lean. Good luck. Make sure your tune is dam good! Alittle ping can kill you engine very soon. Good luck
legerwn
56
Nov 15, 2015 10:21 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
