4.3 to 5.3 Conversion complete, but truck wont start.
Old Jul 25, 2011 | 05:29 PM
WFOSS's Avatar
12 Second Club
Default 4.3 to 5.3 Conversion complete, but truck wont start.
I just completed my 4.3 to 5.3 conversion (2002 silverado) with complete wiring harness, accessories, etc. I used hptuners to flash the 4.3 ecm to 5.3 parameters. Everything took on the tune and I made sure that it had all of the correct info in there for engine size, etc. The problem is that the truck will just crank over and not start. No security light coming on or flashing but no spark. Its gets fuel and pulses a noid light on the injectors. I have the 5.3 computer that came with the engine and wiring harness. I can delete vats out of it and the truck will run fine but the damn security light stays on all the time, even with the key off. I have done the security relearn on it per gm quite a few times to see if that was the issue but no luck, the light still stays on. My question is, why will the truck run with the 5.3 computer, but not the 4.3 computer falshed to 5.3 specs, do I need to disable VATS on the 4.3 computer even though it was the one that was on the truck to begin with? I dont want to run the 5.3 computer because of the security light among other things. Any suggestions are appreciated. Thanks!
Old Jul 25, 2011 | 08:17 PM
Gadgetized's Avatar
Put in the 5.3 computer. Disable G1201, or set it to none. Try that and let us know. I am not sure if it will work, but it is worth a shot.
Old Jul 25, 2011 | 08:32 PM
WFOSS's Avatar
12 Second Club
Cool. I will try that and let you know if it works. Thanks!
Old Jul 26, 2011 | 05:52 PM
WFOSS's Avatar
12 Second Club
Couldnt find that info on hptners. Maybe its just an efilive thing? Or maybe I am missing something.
Bumpers
Aug 4, 2024 09:44 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
