4.3 to 5.3 Conversion complete, but truck wont start.
I just completed my 4.3 to 5.3 conversion (2002 silverado) with complete wiring harness, accessories, etc. I used hptuners to flash the 4.3 ecm to 5.3 parameters. Everything took on the tune and I made sure that it had all of the correct info in there for engine size, etc. The problem is that the truck will just crank over and not start. No security light coming on or flashing but no spark. Its gets fuel and pulses a noid light on the injectors. I have the 5.3 computer that came with the engine and wiring harness. I can delete vats out of it and the truck will run fine but the damn security light stays on all the time, even with the key off. I have done the security relearn on it per gm quite a few times to see if that was the issue but no luck, the light still stays on. My question is, why will the truck run with the 5.3 computer, but not the 4.3 computer falshed to 5.3 specs, do I need to disable VATS on the 4.3 computer even though it was the one that was on the truck to begin with? I dont want to run the 5.3 computer because of the security light among other things. Any suggestions are appreciated. Thanks!
SLOPONY
20
Oct 18, 2016 06:05 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
