2barSD tune?
Old Feb 4, 2007 | 02:30 PM
blown3qtr's Avatar
Default 2barSD tune?
Well I 've finally decided to dive in head frist to my HPTuners 2bar sd operating system and tune. Any tips tricks or advice is appreciated.
Old Feb 4, 2007 | 03:05 PM
03sierraslt's Avatar
I second that, I will be doing the same later this month.
Old Feb 5, 2007 | 03:20 AM
dc96819's Avatar
Tweek little at a time and
Old Feb 5, 2007 | 03:30 AM
Wheatley's Avatar
Truck Sponsor
You did the right thing.
How much boost?What exactly is your setup?
if you want email me your file.
Old Feb 5, 2007 | 07:32 AM
blown3qtr's Avatar
Running a p1sc w/ 8 psi on basically a stock engine. I removed the FMU and installed a 255lph pump and 60# injectors. I will be using a wideband of course.
When tuning the VE table in boost won't you get %error due to BE?
Old Feb 5, 2007 | 09:03 AM
Wilde Racing's Avatar
How do I change this text
The b.e is acounted for, so no not due to b.e. Well I guess the answer is yes you will get an error if your command a/f is different than your true a/f...
Old Feb 5, 2007 | 05:44 PM
blown3qtr's Avatar
Ohh. That makes sense. I read not to enter PE when I first started VE tuning on my stock OS. I assumed the richer commanded AFR would throw things off. Now that I think about it that was probably for tuning w/ LTFT's.
I was planning on starting yesterday but ran out of time before that sorry excuse for a Superbowl. Hope to Reflash my OS and start this evening.
Old Feb 14, 2007 | 08:09 AM
blown3qtr's Avatar
HELL YEAH!!!
The 2bar OLSD is deffinately the way to go for FI. My truck has never run better or been more consistent. I wish I had gotten off my *** and done this sooner.
I still have some fine tuning to do. I'm commanding 12.5AFR in the BE table. It seems to pull pretty good. Does this sound a little lean?
What makes better power in boost? Richer AFR w/ more timing or back off the timing a little and run a leaner AFR (relatively speaking, I don't think I would go any leaner than 12.5)?
Thanks,
Alex
Oh yeah, HPT is the ****!
Old Feb 14, 2007 | 09:12 AM
I shot for 11.2-11.5....
Old Feb 14, 2007 | 10:44 AM
blown3qtr's Avatar
Mine seems to bog down at that rich of an AFR. I will play w/ the BE table once I get VE dialed in 100% though. I guess I could probably run more timing at that rich of an AFR which leads to my 2nd question.
D3moN plz
19
Dec 9, 2015 11:14 PM
06 4.8
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
