2bar OS - Alky injection tuning
Old Jan 8, 2007 | 08:11 PM
  #31
Wilde Racing's Avatar
How do I change this text
Originally Posted by TurboBerserker
Turn off PE.
BINGO, I only use the P.E table for Launching
Old Jan 8, 2007 | 08:26 PM
  #32
KySilverado's Avatar
Are we talking street tunes vs track tunes when we are turning off PE. I don't see turning off my PE on the street. I can and have gone to 6000 rpm without going into boost while tuning VE. I don't want to be at 14.7 AFR there.
Old Jan 8, 2007 | 08:30 PM
  #33
The only reason I have my P.E is to help fuel my low boost/no meth setting, after 2400 rpm, my table drops to 1.07 then 1.05 then 1.02 at 4000 rpm....
Old Jan 8, 2007 | 09:45 PM
  #34
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You can still handle this in the VE table and Commanded Fuel x RPM. Does HPT keep you from this somehow?
Old Jan 9, 2007 | 04:01 AM
  #35
dewmanshu's Avatar
Moderately Differentiated
yeah, that table justin posted up is what you are talking about right? the commanded fuel x rpm? yeah we don't have one of those. nowhere that i know of can we command an afr at any rpm/kpa. The open loop table is only temp based. PE multiplier is only rpm based. and BE multiplier is only kpa based. we have the ve table as a base and then the multiplier tables (only an x-axis)
Old Jan 9, 2007 | 07:01 AM
  #36
I AM A MOTHERF*CKER
AHHH!!! Now I understand.
In that case, PE may not be redundant for HPT
Old Jan 9, 2007 | 07:04 AM
  #37
I think the answer is to tune my VE table in boost regions for meth unless I can run PE Enrich leaner than Boost Erich + Meth which I doubt.
I have put a request in to HPT for a Boost Enrich vs rpm vs map table. Doubt it will happen but no harm requesting.
Old Jan 9, 2007 | 10:20 AM
  #38
dc_justin's Avatar
Hello Dave
That's my suggestion bundled up into one sentence. Way to have a better grasp on the english language than me.
Old Jan 9, 2007 | 10:34 AM
  #39
dewmanshu's Avatar
I am certainly guilty of run on myself. Here's to KY
Old Jan 9, 2007 | 11:01 AM
  #40
kbracing96's Avatar
You need fuel for load not RPM. (that's why is called PE) If your at 5000 rpm and no load, no boost (why would you ever be there anyway??) doesen't mean you need 11.5. 14.7 would not hurt a thing there. How often do you drive around in first gear anyway??
