2007 yukon 5.3 NO Crank
Old Jan 23, 2016 | 10:05 AM
6kimages's Avatar
Default 2007 yukon 5.3 NO Crank
Hi Folks , really struggling with my wifes buggy . It has full power good grounds to chassis and motor. will not crank. It started the other day .She pulled into a mall (she noted on the way there driving , the trans select indicator said she was in park while driving and the speedo did not work) .Then it would not crank. I came there and went through as much as I could given the tols i had (boost cables , channel locks ,cresent wrench and flat screw driver.I confirmed good connections , jumped or crossed the starter and it cranked (but would not fire) hours later we came back it fired up and drove home (with no indicator or speedo) at home the next day i went , short drive parked and will not crank again. Starter relay is activating (feel it click) throttle body is making noise ) when trying . so i assume it has to be after the relay and before the starter somewhere . i would like a schematic on this but??? anybody have a similar iissue or have any ideas??? two years ago it had an issue with locks activating gauges not working , trans not shifting after a months (and spraying connections with realease all ) it cured itself
Old Jan 23, 2016 | 11:21 AM
Wolftrk99's Avatar
Sounds like a nuetral safety/trans range switch issue
Old Jan 23, 2016 | 11:30 AM
6kimages's Avatar
if nuetral safety switch would the starter relay engage?
Old Jan 23, 2016 | 11:38 AM
Wolftrk99's Avatar
Are you getting power at the starter solenoid??
Old Jan 23, 2016 | 04:55 PM
6kimages's Avatar
do not believe so
Old Jan 23, 2016 | 08:51 PM
Wolftrk99's Avatar
Voltmeter will be a necessary tool to figure this out
Old Jan 24, 2016 | 07:58 PM
6kimages's Avatar
starter cranks when i cross batt power to switch wire at the starter , will not crank with key . Can The BCM create this symptom.Oil pressure speedo fuel gauge and rear paower gate , all quit as well . I am curious to know where the power goes after the relay
Old Jan 24, 2016 | 09:29 PM
Wolftrk99's Avatar
Sounds like a bad ground or sonething if all of that quit at same time... I will pull a wiring diagram tomorrow and see if i can help figure out what they all have in common....and where exactly is the power goes after the starter.... I am assuming this is a nnbs tahoe..
Old Jan 24, 2016 | 10:11 PM
Have you changed the starter relay? Have you checked the 40A Starter Fuse?
Old Jan 24, 2016 | 10:38 PM
Some of the other functions you lost are common to the B+ Bus.
Attached Thumbnails 2007 yukon 5.3 NO Crank-07-yukon-b-bus-1.jpg   2007 yukon 5.3 NO Crank-07-yukon-b-bus-2.jpg   2007 yukon 5.3 NO Crank-07-yukon-b-bus-3.jpg
