2005 4.8l engine ticking on acceleration any suggestions
Old Feb 22, 2012 | 10:45 PM
southdadegmc's Avatar
Registered User
Exhaust manifold gaskets replaced and broken bolt fixed took it to mechanic shop today was told that it is not a lifter being that a litter would be heard at all times more than likely a rocker ARM on cylinder 1. Breafly check those out today seem to have some play side to side but no real movement
Old Mar 6, 2012 | 11:01 PM
2006bowtie's Avatar
Originally Posted by Junkyard Dog
How do you know which one is bad?
Did you have to take the exhaust manifold off the head, too? This scares me because the bolts always break.
sorry sir i lost the thread for a while. and i could tell it was coming from the passenger side, so i just pulled the passenger head and pulled all 8 lifters on the side, and the 4th one back was missing the roller and busted to pieces. also the rocker was loose, due to the lifter being shorter and not pushing the push rod fully. and yes, sadly you do have to take the manifold off, BUT on a good note, your taking the head off the motor, making it very easy to pull out the remaining broken bolt IF you break one. if you cant get it out, your local machine shop probably can. i pulled one myself, and had a machine shop do the other because it broke flush. they'll tig weld a piece onto it and pull it out. cost $25 bucks i think? i would recommend that before you attempt drilling it out yourself and potentially ruining your head. if they dont break get some new ones anyway. the one i had them pull out was the first one i tried putting back in and it was a tad rusty and snapped with ease. had to pull the head back off again. ruined my day. lol
Old Mar 11, 2012 | 08:06 AM
GMCDee's Avatar
Oil pump might be going out.
Old Oct 26, 2012 | 07:55 AM
Junkyard Dog's Avatar
I have a 2005 4.8, and it has been doing this for 2 years. When it warms up fully (meaning not just when the thermostat opens but several miles further down the road), the lifter sound goes away, so I have not worried about it.
In the winter, it takes longer for the engine to warm up, so it ticks longer. In the summer, it goes away quicker. Sometimes, it does not do it.
Does this sound like yours, or was it all the time?
Mine is still doing this. A few minutes after the water gets to operating temperature, it goes away. It does not start until the water temperature hits 150 or so.
It is not getting better or worse, so I am leaving it alone for now.
Old Oct 29, 2013 | 10:35 AM
Mine is still doing this. It has been doing it for three or four years now . . .
LARRY01Z28
Aug 1, 2015 10:15 PM
lxcoupe
Jul 27, 2015 08:19 PM
chvy=power
Jul 27, 2015 10:06 AM
85SS/85GN
Jul 22, 2015 12:48 PM
bsgiffor
Jul 19, 2015 11:14 AM
