stuck in pe
Old Sep 4, 2013 | 10:26 PM
gbbmk's Avatar
Default stuck in pe
When I am on the throttle I go into pe or open loop. If i am only on it for brief min it will come out of open loop. However if I stay on at wot or a while the truck stays in open loop regardless of how fast, throttle position or just idle until I shut the truck off for a minute
I have tried working with my tunner guy and he is scratching his head. I have replaced the o2s and the mass is fine. I have long tubes with no cats. Cam intake and heads on a 2004 5.3 Silverado. I am at a loss. Has anyone dealt with this? What else can I look at? Map sensor?
Thanks in advance
Old Sep 4, 2013 | 10:37 PM
BlackGMC's Avatar
Resident Retard
Can you post the tune
Old Sep 4, 2013 | 10:39 PM
gbbmk's Avatar
Unfortunately I cant. Bryan from pcm for less does it, I just monitor through torq. Sorry
Old Sep 4, 2013 | 10:47 PM
smokeshow's Avatar
Mod with training wheels
Can you see commanded AFR?
Old Sep 4, 2013 | 10:48 PM
gbbmk's Avatar
No only o2s and ltfts
Old Sep 4, 2013 | 10:50 PM
smokeshow's Avatar
What is the O2 voltage doing when it is stuck in PE?
Old Sep 4, 2013 | 10:52 PM
gbbmk's Avatar
They goto 8.5 and the trims go to zero. Which is supposed to happen at wot but not after I back off
Thanks for helping btw
Old Sep 4, 2013 | 11:03 PM
smokeshow's Avatar
8.5 or 850?
Old Sep 4, 2013 | 11:44 PM
subeone's Avatar
dfco will null your o2 sensors to read 0 +- trims. And COT will also make you read 0 +- trims, which dumps alot more fuel to keep your cats cool which could last a good while if you said you were wot 'for a while'. How long is that? 1 minute at WOT?
Old Sep 5, 2013 | 05:58 AM
gbbmk's Avatar
Could be a min or longer.
