2003 chevy silverado REduce Engine Power
12 Second Club
Skolman91
I changed the TAC Module in my truck, been hunting a Reduced Engine Power message off and on for about 6 yrs. Within the last 2 months it has gotten worse and going into REP about 3 times a week. I changed my TB, MAF and TAC Module, however I didn't know you had to have the TAC module reprogrammed and my old TAC is on its way back to the O'Reilly home office in Arkansas!!
I spoke with this company who said they can reprogram the TAC but would have to put the tune back to OEM. My truck is tuned (383 stroker with all the fix'ns) and I talked to my tuner and we agree that even though if this company deleted the performance my tuner could put it back in it. However, the truck would not run or run like crap and the reprogramming of the TAC would be compromised because of a buck'n, fart'n truck that has a stock tune with a Big Cam, Big stroke crank, Big Intake, Big TB, Big heads and a big attitude, Had to throw that last one in there!
So, I need an already programmed TAC to get my truck running, a used one from the Salvage yard, then I need to find a truck (same model, year, etc) so I can drive to the the dealer or this guy (with the old TAC installed), install my TAC, have him tune the new module, remove it, put the old TAC back in the "Loaner' truck and take my TAC home and install it into my truck.
What a pain in the dick!
12 Second Club
1FastBrick
I have no idea if the code is specific for the TAC module, no clue what that is or what it means.
I am running a Vic Jr intake and I stuffed all the wires underneath the intake to clean up the outside. A crimped, pinched, bent or otherwise damaged wire is possible. Let me ask you this, how many grounds on the truck? One on each head, one from the hood, one from the battery or two, any others?
I am also running a 90mm Gold Blade and using the X-Link to drive it.
Thanks for the help.
Chad
Chad
Custm2500's Rude Friend
1FastBrick
Chad
Chad
One from the hood goes to the firewall. Then from the firewall to the back of the block.
On the engine harness there are 2 grounds at the back of the block and head.
There is a ground from the battery to the bottom of the block.
There is a few more grounds here and there as well
12 Second Club
Is this NA or forced induction?
Ken
murderedSS
27
10-12-2015 11:13 AM
sleepy_boy1
01-02-2010 01:21 PM
69MyWay
09-07-2009 01:12 PM
