2000 Gmc 5.3 crank wont start
Old Sep 27, 2017 | 09:15 PM
nskeeter99's Avatar
Default 2000 Gmc 5.3 crank wont start
The truck was running trans went. Pulled truck up on ramps pulled tranny replace with a rebuilt one. Now the truck will turn over but no start. The fuel pressure is over 55. All the fuses are good. I have checked and rechecked connections pulled starter too and unplugged and replugged crank sensor. I have no idea if the injectors are firing but the coils are not. I'm sure it's something I have done or did not do. Any thoughts yall?
Old Sep 27, 2017 | 10:24 PM
FFDP's Avatar
Did you miss a ground harness?
Old Sep 27, 2017 | 11:54 PM
nskeeter99's Avatar
well, I call myself checking all plugs, however, I did not disconnect any grounds. I will look for that tomorrow in daylight thought.
Old Sep 28, 2017 | 12:15 PM
nskeeter99's Avatar
Ok, I have to make a correction, I guess my test method for firing was flowed. I sprayed some starter fluid into the intake and it sputtered some. so I guess I'm getting fire, injectors aren't working.
Old Sep 28, 2017 | 03:32 PM
trxmxzx's Avatar
13 Second Truck Club
had similar problem years ago- pulled on crank sensor wires to hard removing starter....one got damaged couldn't tell
Old Sep 28, 2017 | 04:16 PM
nskeeter99's Avatar
I did pull the starter and fidel with the plug. What did you have to do? push the wires back in the plug or what?
Old Sep 28, 2017 | 04:55 PM
trxmxzx's Avatar
removed the pin in the connector, found where wire broke, replaced pin on wire, slipped back into place in connector
Old Sep 28, 2017 | 07:55 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Sounds Like a Vats issue.
Old Sep 29, 2017 | 01:45 PM
nskeeter99's Avatar
What is vats?
Old Sep 29, 2017 | 01:50 PM
nskeeter99's Avatar
ok updates. got noid lights from az. no injector lit. got no fire from any coil, but I can spray starter fluid in and it will stumble makes no sense to me. While fighting with this it fired up once for about 2 seconds. Also, the security light only blinks when the key is in and the door is open. when I crank the truck the light goes out.
