2-bar SD
Old Apr 16, 2010 | 12:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default 2-bar SD
Well guys, I just ordered my new 2-bar map. It should be here by the end of next week, then I plan to start retuning the truck over the weekend.
To those of you who have done this before, do you have any 'tips/tricks' or advice for me? I've watched the tutorials & I've been reading up, and it doesn't seem like it will be too bad. I just don't like surprises. I will be using my HPT Beta. Thanks in advance!
Old Apr 16, 2010 | 12:26 PM
THE-HOE's Avatar
Would you mind telling me where you got the MAP from? maybe even the part number. I am going to SD soon and I am still not exactly sure what i need to get.
Thanks and Good luck to you!
Old Apr 16, 2010 | 12:29 PM
KySilverado's Avatar
Not hard. The tutorials cover it pretty well. Just be sure and and start VE rich. I think they state to multiply the entire table by 10%. Make sure you do that step.
Be prepared to spend a lot of money on gas tuning it. VERRRRRYYY VERRRRYY light throttle transitions.
Old Apr 16, 2010 | 12:45 PM
Atomic's Avatar
I have a gauge for that
Yea...just not too rich or everything goes to ****, ask me how I know
Also, if your wideband is through the EGR port you have to redo it through some other way since the EGR tables arent in the 2bar SD os. I used the ac high pressure since that is pretty common. Im assuming you are using hptuners.
Old Apr 16, 2010 | 01:19 PM
GM part number 12615136, list price is just over $90, if you don't get a discount. If you're in the lower 48, you could go to GMpartsdirect.com and get it for around $45 plus shipping.
The business will be buying the gas. Light throttle transitions??? Crap! That's not gonna be easy, I have a lead-foot.
I have an AEM wideband, and it's wired to connect to my MVPI Pro interface. Hopefully that will make things easier?
Old Apr 16, 2010 | 01:24 PM
Atomic's Avatar
Yea, with the pro interface forget what I said youll be fine.
I bought the ac delc xxx-231 cant remember the first two numbers, i think it was around $40 shipped. Same part I believe.
Old Apr 16, 2010 | 01:32 PM
I get a pretty decent discount with the business.
Old Apr 18, 2010 | 05:02 PM
MikeGyver's Avatar
Why are you using a beta version?
Old Apr 18, 2010 | 05:21 PM
RTT
Old Apr 18, 2010 | 05:24 PM
Atomic's Avatar
that comes with the 2bar OS; you dont need the beta.
