2 bar MAP
Old Sep 18, 2008 | 04:34 PM
GMCDee's Avatar
Default 2 bar MAP
Im goingot have to get rid of the MAF and need to know a few things about the MAP,i need a 2 bar where would i get this???? And can i just get rid of the MAF once i get tuned for the 2 bar? Learning the tuning thing
Old Sep 18, 2008 | 04:42 PM
KySilverado's Avatar
Part # 12580698 is a direct fit. Got mine GMPartsdirect.
Yes if you tune the VE you can run without a MAF.
Old Sep 18, 2008 | 07:32 PM
nonnieselman's Avatar
BUT, you will need a IAT sensor. Run the brown wire and black wire from the MAF to the IAT.
You can use a IAT off a Fbody or S-10. Alot of cars come with them so they are east to find.
Old Sep 18, 2008 | 08:47 PM
charcold-bowtie's Avatar
2-Bar is the pressure reading the map can read.
the Maf reads airflow and is used in upper level rpm operations.
Im currently running 2-bar OLSD.
Sd is speed-density, which is no maf.
Like it was said since our iat sensore are built into the maf, you have to relocate is. msd-2320 is the one i have from summit. No problems and is fast reacting.
Old Sep 18, 2008 | 10:02 PM
GMCDee's Avatar
Thumbs up
the Maf reads airflow and is used in upper level operations.
Thanks for the tips ill be getting these right away,so summit carry the iat's? Thanks again gents appreciate it.
Old Sep 19, 2008 | 01:21 AM
yeah they carry them .I THINK thats the part number. then just cut and hide your maf harness.
calsdad
Jun 14, 2023 11:07 PM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
