2 bar MAP
Im goingot have to get rid of the MAF and need to know a few things about the MAP,i need a 2 bar where would i get this???? And can i just get rid of the MAF once i get tuned for the 2 bar? Learning the tuning thing
BUT, you will need a IAT sensor. Run the brown wire and black wire from the MAF to the IAT.
You can use a IAT off a Fbody or S-10. Alot of cars come with them so they are east to find.
2-Bar is the pressure reading the map can read.
the Maf reads airflow and is used in upper level rpm operations.
Im currently running 2-bar OLSD.
Sd is speed-density, which is no maf.
Like it was said since our iat sensore are built into the maf, you have to relocate is. msd-2320 is the one i have from summit. No problems and is fast reacting.
the Maf reads airflow and is used in upper level operations.
calsdad
Jun 14, 2023 11:07 PM
carid
Oct 1, 2015 09:22 AM
