2-3 Shift Flare
Having a issue in a buddies turbo truck with the 2-3 shift just flaring into the rev limiter. Have tried everything from lowering the shift point, shift times, torque management, and force motor current
Its a built 60e with a ptc converter, he may chime in but behind a 4.8 on about 11 psi. Ive been told it could be the 3-4 clutches wearing but im at a loss on what to change in the tune now.
Help!!!
Help!!!
Its a 00 2 bar sd os. the shift times are at .200 right now have tried .000 to stock shift times with the same results.
Pretty sure we may have just pushed the little 60e too far but the fluid still looks fine, you can literally lift off the gas for a second and get back on it and it shifts.
Not sure what it makes for power but it just ran a 11.9@114 having to lift 2-3 shift with a lackluster 1.8 60'
Did you figure out your shift flare? I am going through that right now also. I have a built 4l60e by rpm transmissions and mine make the least power but still has the issue. I was starting to think wheel speed not matching shift speed? But it does the exact same thing, same gear. A buddies did it and he drove to a different tuner a little ways away. And it got fixed. So I'm guessing it's in the tune also. He just didn't ask. what was . Thanks
Cammed4ever
Sep 30, 2015 03:38 PM
