1997-2002 PCM for MPFI Turbo App??
Old Jun 18, 2007 | 07:49 PM
jmarsa's Avatar
Default 1997-2002 PCM for MPFI Turbo App??
I'm building a single turbo'd 350 using a L31 short block. I want to run a Edelbrock VICTOR EFI manifold with an 90* elbow and a single butterfly TB like on a LS motor.
Will a stock 1997-2002 truck PCM drive 8 injectors? I'm looking for a OEM PCM that will run GEN I motor with a distributor and sequential firing and can be tuned for boost. Due to the cost, I'd prefer OEM over aftermarket or Megasquirt which would be my 2nd choice.
Thanks,
--JMarsa
Old Jun 18, 2007 | 09:21 PM
kbracing96's Avatar
Personally I would go with MegaSquirt. I've setup MS on two motors now, and its a good bang for the buck and turbo with it is easy. I think you could use a OEM pcm, but would be rather difficult, and you would still need some software like EFILive to reprogram it.
Old Jun 18, 2007 | 09:38 PM
jmarsa's Avatar
Thanks for the reply. Any experience with the GM MEFI IV controller?
--JMarsa
Old Jun 18, 2007 | 09:57 PM
kbracing96's Avatar
--JMarsa
I personally never heard of it, or used it, lol.
Old Jun 18, 2007 | 10:19 PM
jmarsa's Avatar
It's a general use Delphi SD controller that started out as a marine EFI unit and then GM put it on the ramjet series of crate engines and industrial motors. It's been used here and there in performance aps but people with knowledge to tune it seems scarce. More data here: http://www.gm.com/automotive/gmpower...700_marine.pdf The current OS is version V (MEFI V).
--JMarsa
Old Jun 21, 2007 | 07:21 PM
scuzz's Avatar
Check out these two threads on other forums. Lots of treat info on Vortec change ups. I'm doing a Ramjet 350 with 12200411 changeover in a 41 Chevy pickup.
http://www.pacificp.com/forum/viewfo...75e1a4b543df07
http://www.thirdgen.org/techboard/tp...-opinions.html
Ron
Old Jun 22, 2007 | 09:07 AM
jmarsa's Avatar
Thanks all for the links. Exactly the info I was looking for.
--JMarsa
XL7
May 5, 2022 01:48 PM
smokeshow
Aug 23, 2015 08:23 PM
bjamick
Aug 5, 2015 10:51 PM
chvy=power
Jul 27, 2015 10:06 AM
GreyChevy
Jul 7, 2015 08:57 PM
