145 amp alt question
i what know if a 145 amp alternator will work on my 2002 Chevrolet Truck Silverado 1500 2WD 4.8L SFI 8cyl. because i have a high power audio system the amp is a lanzar vibe 442n 5000w amp the 12 are 2 pyle pl1290bl blue wave 1200 watts
Like This
Quote
MultiQuote
Edit
Like This
Quote
MultiQuote
Edit
Like This
Quote
MultiQuote
Edit
Like This
Quote
MultiQuote
Edit
Second off, please don't revive old threads. Make a new thread for questions instead
Thirdly, the Vibe is a 2000w amp when bridged, and theoretically only- it's really only going to put out 1100w or so, especially if you're running those subs in series with parallel drivers.
Either way, 145A isn't going to keep the lights from dimming and power being sucked off the battery when you're thumping. The 145amp alt makes about 600w at idle, 1000w at 2000rpm and 1500w at 4000rpm.
All the OE style alternators will be coil-wound style fields (inefficient, cheap, easy to make). The high-end alternators use hairpin windings with heavy gauge wire (high efficiency, expensive, hard to make) and usually have custom cases. Think MechMan or QualityPowerAuto (I run a QPA Mega Amp 320, makes 2000w at idle LOL so I'm kind of partial to them).
iregret
Sep 7, 2015 01:20 PM
