114-115% Idc :/
Old Nov 8, 2007 | 08:51 PM
  #41
Moddoo's Avatar
Originally Posted by dirt_track_racer_81
didnt read all the posts but im kinda leaning more to your pump being bad than running out of injector..on my 5.3 and cam i was gettin 153% duty cycle i put an inline pump in and i was back down to 8x% duty cycle..i have 28lb ls1 injectors in my 6.0 now and cant remember what the duty cycle is but its not over 100 or i would have gone bigger..and i also set my fuel pressure to 60psi
Can you explain how a pump is related to the IDC?
Unless you made a change in the tune.
Old Nov 8, 2007 | 08:54 PM
  #42
dc_justin's Avatar
Hello Dave
Especially with his Speed Density tune... There is no direct correlation except when in closed loop, and even then, it wouldn't go to that extreme...
Old Nov 8, 2007 | 09:22 PM
  #43
dirt track racer 81's Avatar
pump going bad and running out of fuel causing the injectors to work harder??
if thats not possible i cant explain it though... a/f leaned way out and the motor would cut out realy bad..i made a post about this a couple years ago when this happend..put in an inline pump..a/f back to jivin were it should..it worked and that was all i cared about
BlackGMC
Jan 11, 2013 02:53 PM
nonnieselman
32
Sep 2, 2012 08:59 PM
05_quick4door
Apr 12, 2012 11:00 PM
Trezent
Mar 2, 2011 03:06 AM
BlackGMC
13
Apr 30, 2008 09:10 PM
