1-2 shift - 61% Throttle pulled
Old May 23, 2008 | 08:57 AM
  #31
Wilde Racing's Avatar
How do I change this text
What do your "ETC Limits" tables look like?
Old May 23, 2008 | 02:36 PM
  #32
KySilverado's Avatar
Originally Posted by dc_justin
A throttle snap like that is usually the ref limiter. Are you bouncing off of it?
I have the rev limiter at 6100. Only saw 6000 in that scan which is 200 above my commanded 5800 shift point. It may be to close so I will bump it up also to try. Thanks,
Old May 23, 2008 | 02:42 PM
  #33
All at 6100. But just noticed an ETC Limit Enable/Disable field hmmm.....
Old May 23, 2008 | 02:46 PM
  #34
dewmanshu's Avatar
Moderately Differentiated
OH just compare/copy YOUR stock trans settings for crying out loud. You are killing me here!!!
Old May 23, 2008 | 03:15 PM
  #35
I did, I did. It no workie.
Old May 23, 2008 | 03:21 PM
  #36
dewmanshu's Avatar
Oh...
Old May 24, 2008 | 11:40 PM
  #37
mcfarlnd's Avatar
Un-Registered User
fix it?
Old May 25, 2008 | 03:53 PM
  #38
Seems to have. In 4wd its working perfectly. 2wd its blowing past the shift point and hitting the limiter now and pulling the throttle. Just have to play with the shift points now. I've been way to busy with other things to play with it much.
Old May 25, 2008 | 05:12 PM
  #39
trever1t's Avatar
2nd fastest 5.3 ECSB
cool, sounds like you are on track and a little bit of fine tuning will get you back where you want to be!
Old May 26, 2008 | 01:16 AM
  #40
mcfarlnd's Avatar
Un-Registered User
what exactly did it end up being?
