08 TBSS Hanging Idle after rev
I am tuning a buddies TBSS, just did a 402ci swap into. So far everything seems fine exept that after a rev the rpm takes a couple sec to start droping down to idle. Setup is as follows, LS2 402, trick flow heads, 11.5-1 comp, 232/236 114lsa cam, ported stock 87mm tb. This motor was out of a 07tbss and idle didnt hang in it. Same scaler is being uses between the two, but tps hangs high for a couple secs before dropping. What should i do to adjust this? Still learning Gen4 i am used to Gen3 pcm's. Thanks
What airflow and throttle tables did you change from the stock TBSS tune? Also, the effective throttle area for idle may have been altered depending on how close the porting got to the center of the throttle bore.
drummer0415
11
Oct 24, 2015 08:16 PM
nic351
Sep 24, 2015 09:43 AM
maxspeed05V
Sep 23, 2015 10:48 AM
