06 gmc controling the low speed e fans
Old Jul 10, 2011 | 03:35 PM
6789olds's Avatar
Default 06 gmc controling the low speed e fans
looking to add a manual switch to the low speed fans so it can be controlled while slow speed 4 wheeling where can i find the wire ? under the fan relays looks like there are 2 blue wires? or the wire number on the pcm thanks
Old Jul 18, 2011 | 03:39 PM
BadAssChevy327's Avatar
my buddy did this on his truck. only thing is the way he did it caused a check engine light.
but im subing to see other ways how to
Old Jul 18, 2011 | 04:36 PM
Atomic's Avatar
I have a gauge for that
Are you wanting to be able to turn them off or manualy turn them on low?
Old Jul 18, 2011 | 05:58 PM
6789olds's Avatar
Turn them on low with a switch
Old Jul 18, 2011 | 06:35 PM
Atomic's Avatar
Pin 42 on the BLUE pcm connector is the one that controls the low speed fan. Splice into that wire and connect it to a simple 2 position switch, and the other side of the switch to any ground. Flipping the switch will turn it on, and it should still operate automatically otherwise.
thunder550
Oct 8, 2015 04:53 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
ullose272
Jul 19, 2015 04:14 PM
