05+ fan convert
Old Oct 4, 2011 | 03:31 PM
  #21
Team Paulie's Avatar
Registered User
Originally Posted by Alpinestar
I bought trick performances electric fan kit. They drop right in and bolt up in about 2 mins. With the ls1 fans you have to find your own way to attach them.
Have you had any issues with this set up? also how did you wire em up and were did you get em?
Old Nov 18, 2011 | 08:05 PM
  #22
Registered User
ok beating a dead horse, but I just got done about a hour ago doing the Ls-1 swap and black bear harness install, What temp are these suppose to turn on at? The gauge is right at around 210 maybe a bit less.
Old Nov 19, 2011 | 08:17 AM
  #23
aknovaman's Avatar
Efans DIY 04 Escalade video by aknovaman - Photobucket
Old Nov 19, 2011 | 09:11 AM
  #24
Registered User
The mounting is not the issue, the gauge will go to 210,drop a position, stay there.
Old Nov 21, 2011 | 08:50 PM
  #25
Formerly 99-2door-08/30/2010
Depends on what they are set to in your tune. Ask your tuner.
Old Nov 21, 2011 | 08:53 PM
  #26
lady3bglover's Avatar
Originally Posted by charcold-bowtie
You should be able to find ls1 fans cheaper than that, maybe post up on tech. that sounds about fair for truck fan, but you need the wider radiator as well, then they bolt right up.
Im not sure what else your asking tbh.
Genesis has the 34" all aluminum radiators for $168+tax/s&h. Matched up perfect to Ls1 fans.
Old Nov 23, 2011 | 02:50 PM
  #27
Registered User
Been a little too cold around here to have em kick on by them selves, but if I jump em they work fine, temp around here hasent gotten above 50 degress for the past two weeks.
Suppose to kick on at 204 and off at 199 on low and if AC line pressure is going, kick on a 211 off at 207 I believe for the high setting.
But I'm also thinking of running Engine ice too.
Old Nov 24, 2011 | 01:00 AM
  #28
Alpinestar's Avatar
sorry i just saw this post, but no problems.
I would just set them to the specs of the '05-up models. Engine ice is kind of expensive... why not just swap out your thermostat for a 180* one? Oh and if you swap thermostats you will probably have to adjust the temps your fans come on again.
Old Nov 27, 2011 | 12:04 AM
  #29
Registered User
I get engine ice from work at a pretty hefty discount plus we always have at least 12 half gallon jugs in stock,drain,flush,fill,done.
Old Nov 29, 2011 | 07:16 AM
  #30
SnakeOiler's Avatar
Is there a problem with that. Sounds normal to me.
