02 OS in a 2k with 80 segment swap
Old Nov 12, 2011 | 02:22 PM
slowec's Avatar
Default 02 OS in a 2k with 80 segment swap
OK, Here goes. Installed the Jakes 4l80 w/trans brake. Jumped to a 02 operating system and performed the segment swap. Problems...
Trans shift to hard at light throttle... guessing to lessen line pressure?
Air/fuel is all over the place now... F' it, working on 2 bar swap now
Need to know what needs to be changed to make SURE the transbrake does not engage because of manual overide shifting.
THANKS for looking...
Old Nov 12, 2011 | 06:22 PM
slow67's Avatar
Gingervitis Addict
HPTuners or EFILive?
Old Nov 12, 2011 | 06:28 PM
nonnieselman's Avatar
If your using 2bar SD, did you disable the fail safe for the MAF and max line pressure? Im not around my laptop so im not sure what its called.
does the transbrake have wires of its own? Sorry, i dont know how its wired up.
Old Nov 12, 2011 | 06:36 PM
slowec's Avatar
I am using EFILIVE. I did disable the trans parameters. Brake hooks up using the factory harness. Have not got that far. Using cos3 and gonna try it with mo PE, just straight rpm/2 bar map.
Old Nov 12, 2011 | 06:49 PM
Ahh ok. I can send you my tune if you need it.
Old Nov 12, 2011 | 07:09 PM
TIM Z's Avatar
11 sec. Truck Mod
Im using a 2000 OS with no probs, maybe you could try switching OS ???
Old Nov 12, 2011 | 10:45 PM
slowec's Avatar
I would like to build my own. I'd love to look at your for comparing though. I really need the correct maps to log a serial lc1 for a 2bar. My e-mail is rodneyhorne1@gmail.com
THANKS
Old Nov 12, 2011 | 11:12 PM
Aight. When i find some wifi ill shoot it your way
Old Nov 12, 2011 | 11:14 PM
slowec's Avatar
woo hoo ... THANKS!
Old Nov 12, 2011 | 11:16 PM
Oh and im runnin my 2000 pcm with a 2002 OS of 12212156. Running 0202003 COS3.
