01 silverado efans on low all the time
Old Mar 28, 2015 | 02:52 PM
GMCtrk's Avatar
Procure an OEM harness.
I'm running the stock harness on my 2000 with OEM efans and it runs perfect. And looks stock too.
Old Mar 28, 2015 | 02:54 PM
Dangeruss5.3's Avatar
Cool. Let me know what you find. If there is a way to change the one i have i will. Good luck!
Old Mar 28, 2015 | 02:55 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I have one but the fan ends are busted.
I am going to modify it right now using the how too. If it works I will get replacement ends.
https://www.performancetrucks.net/fo...-chevy-484892/
Old Mar 28, 2015 | 04:30 PM
1FastBrick's Avatar
I was just informed the 99-00 operating systems don't function correctly for E fan swaps. I was told to do a full Flash to a 2002 operating system and enable the fan settings.
So far this has worked. The fans don't run after I turn the engine on.
I need to copy all my tables for the engine swap over before I let it run too long. Also Need to Verify the correct VIN is still present.
Old Mar 28, 2015 | 05:20 PM
So how do you go about swapping to the 2002 system?
Old Mar 28, 2015 | 05:23 PM
1FastBrick's Avatar
Take an 02 operating system. Add your VIN number.
Change Fan settings.
Change anything else that was modified in your last operating system.
Do a full flash.
Old Mar 28, 2015 | 05:25 PM
Where do you get an 02 operating system?
Old Mar 28, 2015 | 05:51 PM
1FastBrick's Avatar
Damn It!!!
The Trigger wire connection wasn't seated all the way to the fan harness when I went to test the new operating system. Now I have to let it cool down. Before I can check it again.
Old Mar 28, 2015 | 05:54 PM
1FastBrick's Avatar
If its EFI live and you have a V1 or V2 I can try posting it or I can send you a stock one for a 5.3L
They have a 4.8 and an 8.1 on tune file depot for 2002 operating system.
If you using an Auto cal your tuner will need to change it for you and send you the update to use with your device.
Old Mar 28, 2015 | 06:24 PM
1FastBrick's Avatar
It does in fact work correctly with a 2002 operating system flashed into the 99 PCM.
Here is an 02 Operating system for 2002 LM7 5.3L engine in EFI Live format.
Edit: I also added the same 2002 file in HP tuners format.
