01 silverado efans on low all the time
Old Mar 29, 2015 | 09:35 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Dangeruss5.3
5.3 with head work, cam, ported throttle body and intake. I just wasnt sure if i could copy my tune over the 02 OS or just go through and change everything.
You have to do it 1 at a time for the tables that are changed.
You can go into your OS and double click on the upper left corner of the table it will highlight all values.
Hit cntrl c at the same time to copy and then go to the 2002 OS and click the left upper corner to highlight all values and hit cntrl v to paste.
You can use the fan values from a 2005-07 classic to start with.
Old Mar 29, 2015 | 09:41 PM
  #32
Dangeruss5.3's Avatar
Awesome! Thanks again for all the help. Your a life saver!
Old Mar 29, 2015 | 09:48 PM
  #33
1FastBrick's Avatar
No Problem. I just went through the same head ache.
I am putting together a DIY thread soon for the E fan swap
Old Mar 29, 2015 | 09:57 PM
  #34
Probably wouldnt be a bad idea. Will be nice to have the updated info for the older OS trucks.
Old Apr 2, 2015 | 07:12 PM
  #35
So I finally got around to changing my OS. I did a full flash and started it up and no fans! The fans seem to be working properly off of temp control. HoweVer when I turn on the a/c the high fan does not come on. Is there anyway to have the pcm control the fan when the a/c comes on or will I just have to tap into the a/c wire??? I have the a/c setup to control fan 2 instead of the recirculation door.
Old Apr 2, 2015 | 07:38 PM
  #36
1FastBrick's Avatar
My Harness had a deal to tap it to the AC under the fuse box as described in this thread---> https://www.performancetrucks.net/fo...-chevy-484892/
I am not sure how you would tie it into the harness you have.
Have you tried recirculation instead of fan 2 to see if it controls the fans that way?
Old Apr 2, 2015 | 08:19 PM
  #37
2002_Z28_Six_Speed's Avatar
When I turn the AC on I get two fans low and not one fan high. I only get two fans high if the truck is very hot.
Old Apr 2, 2015 | 08:38 PM
  #38
1FastBrick's Avatar
Is used the PCM of NC fan harness. They happen to be on sale for easter right now.
1999-2002 Full Size Truck Dual Fan Conversion Kit
I didn't get any pictures of the install but I have a another harness I can take pictures of.
It's really a nice piece for the money.
As mentioned it uses pin's Red 33 and Blue 42 along with an AC trigger wire under the fuse block.
It controls high and low with heat range as well as high when the AC system cycles.
Old Apr 2, 2015 | 09:00 PM
  #39
I have not tried it as recirculation yet? Ill try it and see!
Old Apr 4, 2015 | 11:10 AM
  #40
It looks like I would need this harness to control my fans with the a/c on. Might have to upgrade one day! Thanks again for all of the help!
