[HP Tuners] Idle drop at low speeds
Old Jan 23, 2011 | 11:21 PM
RSTinOKC's Avatar
Yep, problem started about 5k miles ago...I made the IAC hole much smaller.
I've noticed in the stock tune on the cracker table several of the low speed low rpm values are at zero...I think I'll start with these and report back.
Old Jan 23, 2011 | 11:45 PM
Atomic's Avatar
I have a gauge for that
I would start with the base running airflow tables....what are the idle trims doing?
Old Jan 24, 2011 | 12:04 AM
Wheatley's Avatar
Truck Sponsor
You made the IAC hole smaller??Is this on your 04 model with ETC??I am curious
Old Jan 24, 2011 | 10:28 AM
RSTinOKC's Avatar
Yeah, its etc...I don't know what else to call the opening. Whatever it is, I put a piece of bic pen in the hole and packed metal filler around it.
Old Jan 24, 2011 | 04:30 PM
MikeGyver's Avatar
The hole in the throttle blade?
Old Jan 25, 2011 | 07:49 AM
RSTinOKC's Avatar
This one:
Atomic, when adjusting base airflow values what are good increments to use: full point, tenths, hundredths?
Old Jan 25, 2011 | 09:08 AM
Atomic's Avatar
Try adding 2g/sec to the whole row, and if that helps you need to go back and properly do the whole table.
Old Jan 25, 2011 | 09:21 AM
tarinitup's Avatar
9 Second Truck Club
Take out the filler
Old Jan 25, 2011 | 09:31 AM
krambo's Avatar
This one:
1. Shouldn't have altered the TB in that manner.
2. Base running airflow (RAF) can easily be scanned (on an 04 model) to find out the EXACT values your truck requires, avoiding the guesswork.
Old Jan 25, 2011 | 09:37 AM
TXsilverado's Avatar
put a stock untouched throttle body back in it. problem solved.
