Running out of fuel?
Old Jul 18, 2009 | 08:35 PM
Will's Avatar
Default Running out of fuel?
Hey guys I tuned my truck with a tune that was pulled from various other tunes and came up with something that works better than what I had, but still getting me tons of KR. I have a 2000 Silverado with a Whipple at about 5-6psi and a 6.0L. I am attaching my EFI log, and wondering if anyone can help me with this. I think I am running out of fuel based on my LT's, but maybe someone can point me in the right direction. Thanks.
File Type: efi
Old Jul 18, 2009 | 09:46 PM
2004SSS's Avatar
wideband would be more accurate. also if your getting knock retard or possibly audible knock you need to get off the throttle .im also guessing your running a non intercooled whipple so iats are also probably up there not helping . do you have any logs?
Old Jul 18, 2009 | 09:50 PM
Will's Avatar
I attached my current log on the first post. It is with EFI Live. IATs when knock occurs is around 144 F. Yes, it is non-intercooled.
Old Jul 18, 2009 | 10:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Thats fairly high for iat's.. I would add a meth or ic....
Old Jul 18, 2009 | 11:48 PM
Will's Avatar
What about my LT's in the 12's?!
Old Jul 18, 2009 | 11:59 PM
53RUSSELL's Avatar
Where do you have your fuel enrichment set out? Post up your tune.
Old Jul 19, 2009 | 12:02 AM
Will's Avatar
Here it is.
File Type: tun
Old Jul 19, 2009 | 12:04 AM
53RUSSELL's Avatar
You need to log your GM.INJ1PW and this CALC.INJ1DC to see if the injector max out. I would get wide band to see where AFR is. You should be going into fuel enrichment some where after 95kpa.
Old Jul 19, 2009 | 12:09 AM
Will's Avatar
I have an OS that doesn't support either of those PIDs. I wish I had the Duty Cycle one, that would really help.
Old Jul 19, 2009 | 12:11 AM
53RUSSELL's Avatar
IF was me i would move up to a cos3 to get boost settings. I would up grade your injects to of min. 8.1 for 6lb. Your b3605 way to lean after 90kpa.
